Forum >CAN BUS Shield For Arduino using on a Lattepanda
i have a general question. How can I use Arduino Uno Shields with a lattepanda? Is there an adapter shield?
... and in special I want to use the CAN BUS Shield For Arduino on a LattePanda. How shall I connect it to the Arduino Conector on the LP?
Thanks for your help
Carsten
Carsten
2017-04-15 02:55:01 Hi there are some arduino pin on lattepanda, if you want to control your shield, you might need a arduino controller. Just insert the shield into the arduino controller, then connect your arduino controller to lattepanda. Please refer to the lattepanda pin definition.
Wendy.Hu
