Forum >DF 4WD Combining encoder code with motor code
3D PrintingGeneral
userHead Thad 2012-01-17 10:56:13 8271 Views2 Replies
How do I combine the following two sets of code? Can anyone send me a copy of code that is similar to this, i.e., code that will make the DF 4WD robot move around as well as respond to the encoders?
I have successfully used the following code to run my DF Robot 4WD platform through a series of movements:
//Standard PWM DC control
int E1 = 5; //M1 Speed Control
int E2 = 6; //M2 Speed Control
int M1 = 4; //M1 Direction Control HIGH = reverse left side
// LOW = forward left side
int M2 = 7; //M2 Direction Control HIGH = forward right side
// LOW = reverse right side
void stop(void) //Stop
digitalWrite(E1,LOW);
digitalWrite(E2,LOW);
void setup(void)
pinMode(5, OUTPUT);
Serial.begin(19200); //Set Baud Rate
void loop(void)
analogWrite (E1,190); // Go Forward
digitalWrite(M1,LOW);
analogWrite (E2,120);
digitalWrite(M2,HIGH);
delay(10000);
stop();
delay(3000);
analogWrite (E1,190); // slight right turn
analogWrite(E2, 70);
delay(2800);
stop();
delay(3000);
delay(12000);
stop();
delay(4000);
I have since added encoders to the platform and would like to use the following code to control these encoders:
const byte encoder0pinA = 2;//A pin -> the interrupt pin 0
const byte encoder0pinB = 4;//B pin -> the digital pin 4
byte encoder0PinALast;
int duration;//the number of the pulses
boolean Direction;//the rotation direction
Serial.begin(57600);//Initialize the serial port
EncoderInit();//Initialize the module
Serial.print("Pulse:");
Serial.println(duration);
duration = 0;
delay(500);
void EncoderInit()
Direction = true;//default -> Forward
pinMode(encoder0pinB,INPUT);
attachInterrupt(0, wheelSpeed, CHANGE);
void wheelSpeed()
int Lstate = digitalRead(encoder0pinA);
if((encoder0PinALast == LOW) && Lstate==HIGH)
int val = digitalRead(encoder0pinB);
if(val == LOW && Direction)
Direction = false; //Reverse
else if(val == HIGH && !Direction)
Direction = true; //Forward
encoder0PinALast = Lstate;
if(!Direction) duration++;
else duration--;
As I said above...My question is how do I combine these two sets of code? Can anyone send me a copy of code that is similar to this, i.e., code that will make the DF 4WD robot move around as well as respond to the encoders? When I upload the encoder code by itself, nothing happens to the robot. I assume I need to somehow mesh these two sets of code together, but I don't know how.
2012-01-18 20:15:25 Thanks for this code...I haven't uploaded it yet, but will do so soon.  I'm glad to have some code from which to start.
Thanks,
Thad
userHeadPic Thad
2012-01-17 23:40:38 Hi,
Here is another sample code that might help you on your way.
Code: Select all
// # Editor    : Lauren from DFRobot
// # Date      : 17.01.2012
// # Product name: Wheel Encoders for DFRobot 3PA and 4WD Rovers
// # Product SKU : SEN0038
// # Description:
// # The sketch for using the encoder on the DFRobot Mobile platform
// # Connection:
// #        left wheel encoder  -> Digital pin 2
// #        right wheel encoder -> Digital pin 3
#define LEFT 0
#define RIGHT 1
long coder[2] = {
  0,0};
int lastSpeed[2] = {
  0,0};
void setup(){
  Serial.begin(9600);                            //init the Serial port to print the data
  attachInterrupt(LEFT, LwheelSpeed, CHANGE);    //init the interrupt mode for the digital pin 2
  attachInterrupt(RIGHT, RwheelSpeed, CHANGE);  //init the interrupt mode for the digital pin 3
void loop(){
  static unsigned long timer = 0;                //print manager timer
  if(millis() - timer > 100){
    Serial.print("Coder value: ");
    Serial.print(coder[LEFT]);
    Serial.print("[Left Wheel] ");
    Serial.print(coder[RIGHT]);
    Serial.println("[Right Wheel]");
    lastSpeed[LEFT] = coder[LEFT];  //record the latest speed value
    lastSpeed[RIGHT] = coder[RIGHT];
    coder[LEFT] = 0;                //clear the data buffer
    coder[RIGHT] = 0;
    timer = millis();
void LwheelSpeed()
  coder[LEFT] ++;  //count the left wheel encoder interrupts
void RwheelSpeed()
  coder[RIGHT] ++; //count the right wheel encoder interrupts
userHeadPic Hector
