Forum >Gravity keyboard module problems
userHead jbenedetto0584 2017-04-18 04:08:34 1441 Views3 Replies
has anyone had issues with the keyboard module? I purchased one, wired and programmed exactly as the example describes, and it is worthless. I press S1 and it returns S3, S4 and S5.
2017-04-25 21:53:51 I run the code and test the buttons, it works fine, maybe it's because of the button's structure, when I press S1, the serial monitors showed "S2 OK". try more times and press harder. userHeadPic robert.chen
2017-04-22 08:30:09 The baud rate is correct. I have feedback in the serial port but it is inconsistent. As I said, I press S1 and it returns S3, S4 and S5. I press S3, and I receive S2, S3 and S4. userHeadPic jbenedetto0584
2017-04-20 22:31:29 Hi
Do you mean when you try to press the button, then no feedback in the serial port, right? If so, did you choose the buad rate correctly?
userHeadPic Wendy.Hu
