Sensor SHT20 I2C how to better fix it in the field
Hello !
Does anyone have experience with the humidity and temperature sensor SHT20 I2C.
https://wiki.dfrobot.com/SHT20_I2C_Temp ... U__SEN0227
I need to install these sensors in a natural park .. and I was thinking to fix them to the trees, tying the with a rope (touching the white cover of the sensor) in order to avoid that it moves.
I am worried about the contact between the sensor and the wood .. whether this can produce variation in the measurements
How do you fix normally your sensors ?
I was also thinking to fix the black cable and leave "free" the sensor leaning .. however, in this case, i think that any movement can modify the measurements..
What is the best way? Could you advise me ?
I look forward to your reply
