Forum >Touch panel don't work
I just got LP this week, starting to put it together, everything hook up but the touch screen don't work, first i find the LP the touch connector is missing the lock in the back or it don't have one at all? or the touch overlay is bad, I didn't buy the overlay from DFrobot, because i forgot i place with the LP order instead order local from Amazon, the device manager find the touch overlay in HID - Goodix touch HID, i try to install the ver 1.0 or 1.1 drive still can't get it to work. Is it the LP is bad or the overlay is bad? let me know which one is bad than if overlay is bad i will RMA with Amazon, if the LP is bad i will need an RMA with you.Please help, Thanks!
2017-07-28 01:03:27 I have the same problem with LP.
I received the LP without block flex of tactil .... I knew it when later I bought the touch panel and screen 7 "sold for LP here.
We need a solution, we are several users with this problem
josiloco69
