Forum >( Gravity: Digital Adjustable ) Infrared Proximity Sensor
userHead mohd 2020-05-21 01:08:03 1429 Views1 Replies
Could you please standardised the usage colors of wires for the ( Gravity: Digital Adjustable ) Infrared Proximity Sensor. If I use SKU:SEN0019, the wires are as follows Brown: +5V; Black: Signal; Blue: GND whereas for SKU:SEN0239, the wires are as follows: Blue: D Switch Signal; Isabellinus : VCC 3V or 5V; Black: GND Ground. At certain time, I just forgot what model I bought, it is confusing testing the right wire for the connection.
2. My Arduino VCC pin is supplying 500MA (the reading is obtained from multimeter) and the SKU:SEN0019 current is 100MA. Is it safe?
