Forum >I2C to Dual UART Module with Pi4 - Code examples?
userHead richardjsears 2020-05-29 21:18:35 1567 Views4 Replies
I am looking at using the DFR0627 module with my Pi4, but there are no examples for the Raspberry Pi, only the Arduino. Does this work with the Pi and do you have any code examples for the Pi..?
Thank You
2023-04-03 06:19:04
Following up on the comment from 2021-04-19 by 347945801. Was there a python library developed for this module?
userHeadPic williamapardis
2021-04-20 01:20:37 The Python library of this product has been requested by the product manager to the engineer, and it may be available soon. userHeadPic 347945801
2021-04-17 06:52:03 What chip is the i2c serial interface chip compatible with ? I found the spec sheet for it but it's in Chinese. Maybe it can be used with a driver and application software for another device. userHeadPic adams
2021-04-17 05:20:45 Same problem. And, I bet there's no i2c driver for it either since it uses a Chinese i2c chip (Weikai WK2132-ISSG), which is not mentioned anywhere in their literature or board schematic. userHeadPic adams
