Forum >DFrobot heart rate sensor with Nodemcu esp32 + firebase
Easy IoT General
userHead Account cancelled 2020-06-21 09:25:06 6260 Views0 Replies
Hi, I have been working on the project using the heart rate monitor sensor with nodemcu esp 32. I have tested it on the digital mode and it works perfectly but when I try to push the data to firebase, it just keeping showing zero BPM and I wonder why. Anyone could help with this problem, please?
Code:
#define heartratePin 32
#include "DFRobot_Heartrate.h"
#include <WiFi.h> //1. Include WiFi.h
#include "FirebaseESP32.h" //2. Include Firebase ESP32 library (this library)
// Set these to run example.
#define FIREBASE_HOST "test.firebaseio.com"
#define FIREBASE_AUTH "hW8qlM48dGkxxxxxxxx1Pq5UD21YgPq2E0c"
#define WIFI_SSID "Gummya"
#define WIFI_PASSWORD "testtest1"
DFRobot_Heartrate heartrate(DIGITAL_MODE); ///< ANALOG_MODE or DIGITAL_MODE
FirebaseData firebaseData; //3. Declare the Firebase Data object in the global scope
Serial.begin(115200);
initWifi();
uint8_t rateValue;
heartrate.getValue(heartratePin); ///< A1 foot sampled values
rateValue = heartrate.getRate(); ///< Get heart rate value
if(Firebase.setInt(firebaseData,"HeartBeat/BPM_data", rateValue)){
//if (firebaseData.dataType()== "Int")
Serial.println(rateValue);
delay(20);
void initWifi(){
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(300);
Serial.println();
Serial.print("Connected with IP: ");
Serial.println(WiFi.localIP());
Serial.println();
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
Firebase.reconnectWiFi(true);
//Set database read timeout to 1 minute (max 15 minutes)
Firebase.setReadTimeout(firebaseData, 1000 * 60);
//tiny, small, medium, large and unlimited.
//Size and its write timeout e.g. tiny (1s), small (10s), medium (30s) and large (60s).
Firebase.setwriteSizeLimit(firebaseData, "tiny");
Serial Monitor output:
Got the FirebaseESP32.h library from --> https://github.com/mobizt/Firebase-ESP32
I've searched for quite awhile but ended up with nothing, Im fairly new to arduino and programming so please help me. I will be grateful to you.
Any help will be highly appreciated. Thanks !
