Noob trying to make sure I am buying compatible boards for project. Mega multi IO Shield for 2560
Hello I am a noob and hoping to find some guidance purchasing compatible parts. I had already bought some items that don't seem to be compatible so I don't want to make the same mistake again.
The code below is Platformio created by others that I hope to alter and make work for my project. I have been researching for weeks so trying to develop a test bench for my personal use.
I believe the project to be working correctly with a Mega 2560 and interface shield but I want to add the H bridge motor driver shield (last link) to fire the injectors (low impedance). I don't think (unsure) that I can use the motor shield as well as the LCD interface because they use the same pins. So I was looking at the Mega multi IO shield and wondering if it would work in one of the positions. I may not be understanding the use of the Mega Multi IO shield so please feel free to correct or expand my understanding of it.
I did search the board but not very much information with the terms I used.
https://www.dfrobot.com/product-655.html Mega 2560
https://www.dfrobot.com/product-990.html Mega multi IO shield
https://www.dfrobot.com/product-51.html interface
I want to add the quad motor driver shield below
https://www.dfrobot.com/product-1513.html
I hope I have the code posted correctly but it doesn't look correct when I scroll through it. Additionally I realize I will have to add the code for the motor drive shield if I am able to make this work.
Fuel injector tester front-end.
The LCD driving routines were found at https://electropeak.com/learn/, from a
tutorial by Saeed Hosseini @ Electropeak
Pin-outs on my mega2560 (clone):
Pin 22: Fuel pump relay (HIGH = pump off)
Pin 50 - 53: Injectors
#include <Arduino.h>
#include <EEPROM.h>
#include <LiquidCrystal.h>
#include <string.h>
#include <stdio.h>
//LCD pin to Arduino
const int pin_RS = 8;
const int pin_EN = 9;
const int pin_d4 = 4;
const int pin_d5 = 5;
const int pin_d6 = 6;
const int pin_d7 = 7;
const int pin_BL = 10;
// fuel pump relay pin - mega pin 40
const uint8_t pin_FUEL_PUMP_RELAY = 22;
// injector pins - mega pins 50 through to 53
const uint8_t pin_INJECTOR_1_MASK = B00001000; // pin 50
const uint8_t pin_INJECTOR_2_MASK = B00000100; // pin 51
const uint8_t pin_INJECTOR_3_MASK = B00000010; // pin 52
const uint8_t pin_INJECTOR_4_MASK = B00000001; // pin 53
// Make PORTB pins 50 - 53 outputs
const uint8_t dir_INJECTORS_OUT = B00001111;
typedef struct leak_test_params {
int seconds;
int max_seconds;
int min_seconds;
int second_step;
} leak_test_params;
typedef struct {
int seconds;
int max_seconds;
int min_seconds;
int second_step;
short duty;
int duty_step;
int min_duty;
int max_duty;
int rpm;
int rpm_step;
int min_rpm;
int max_rpm;
} rpm_mode_params;
typedef struct {
int seconds;
int max_seconds;
int min_seconds;
int second_step;
} full_flow_params;
typedef struct {
int pulses;
int max_pulses;
int min_pulses;
int pulse_step;
long long microseconds;
long long max_microseconds;
long long min_microseconds;
long long microsecond_step;
} pwm_params;
typedef enum {
LEAK_TEST,
RPM_MODE,
FULL_FLOW_MODE,
PWM_MODE,
NO_MODE
} operation_t;
typedef enum {
NORMAL_MODE,
IN_MENU_MODE,
NO_STATE
} state_t;
typedef enum button_t {
NO_BUTTON,
LEFT,
RIGHT,
UP,
DOWN,
SELECT
} button_t;
button_t LAST_BUTTON = NO_BUTTON;
operation_t CURRENT_MODE = LEAK_TEST;
operation_t LAST_MODE = NO_MODE;
/* The PARAM_NUM variable is used to determine which parameter in a list
of up to three (for RPM mode) the user interface is currently showing as
modifiable */
int PARAM_NUM = 0;
/* The time a button was last pressed. Used for the UI handling of press-and-hold */
unsigned long last_button_press_time = 0;
/* global parameters for the various test modes. These are the initial values when
the arduino starts up, but they get overwritten with the saved values if any are
stored in the eeprom */
leak_test_params LEAK_TEST_PARAMS = { .seconds = 60,
.max_seconds = 300,
.min_seconds = 10,
.second_step = 10 };
rpm_mode_params RPM_MODE_PARAMS = { .seconds = 15,
.max_seconds=60,
.min_seconds = 5,
.second_step = 1,
.duty = 50,
.duty_step = 1,
.min_duty=1,
.max_duty=99,
.rpm = 1000,
.rpm_step = 200,
.min_rpm = 600,
.max_rpm = 6000 };
full_flow_params FULL_FLOW_PARAMS = { .seconds = 10,
.max_seconds = 30,
.min_seconds = 1,
.second_step = 1 };
pwm_params PWM_PARAMS = { .pulses = 30,
.max_pulses = 100,
.min_pulses = 1,
.pulse_step = 1,
.microseconds = 1000,
.max_microseconds = 1000000, // 1s
.min_microseconds = 100, // 0.1ms
.microsecond_step = 10 // 0.01ms
}; /* 100 pulses @ 5ms */
/* User interface:
* Test modes:
* Leak test:
* Run pump for x seconds (or until cancelled)
* RPM mode:
* Simulate X RPM. Open injectors for nn% of duty cycle
* Full flow mode:
* Keep injectors fully open for x seconds
* PWM mode:
* Open injectors for x.y milliseconds, n times.
* Status line: ________________
* Leak test: xx s 12
* RPM mode: [email protected]@50% 12
* Full flow: xx s 12
* PWM mode: [email protected] 12
LiquidCrystal lcd( pin_RS, pin_EN, pin_d4, pin_d5, pin_d6, pin_d7);
/* display the top line on the LCD */
void set_top_line(operation_t mode)
char buf[17];
switch(mode) {
case LEAK_TEST:
snprintf(buf, sizeof(buf),"Leak Test Mode ");
break;
case RPM_MODE:
snprintf(buf, sizeof(buf),"RPM Mode ");
break;
case FULL_FLOW_MODE:
snprintf(buf, sizeof(buf),"Full Flow Mode ");
break;
case PWM_MODE:
snprintf(buf, sizeof(buf),"PWM Mode ");
break;
default:
snprintf(buf, sizeof(buf),"Unknown mode ");
lcd.setCursor(0,0);
lcd.print(buf);
/* Display the bottom line on the LCD (at least in menu mode) */
void set_bottom_line(operation_t mode, button_t button)
/* Print bottom line */
char buf[17];
/* the pN_markers are used to show the user which parameter
he/she can currently modify */
const char *p0_marker = PARAM_NUM == 0 ? ">" : " ";
const char *p1_marker = PARAM_NUM == 1 ? ">" : " ";
const char *p2_marker = PARAM_NUM == 2 ? ">" : " ";
switch (mode) {
case LEAK_TEST:
snprintf(buf, sizeof(buf), ">%d seconds ",
LEAK_TEST_PARAMS.seconds);
break;
FULL_FLOW_PARAMS.seconds);
break;
case RPM_MODE:
// example: ">60s 1000rpm 75%"
snprintf(buf, sizeof(buf), "%s%ds%s%drpm%s%d%% ",
p0_marker, RPM_MODE_PARAMS.seconds, p1_marker,
RPM_MODE_PARAMS.rpm, p2_marker, RPM_MODE_PARAMS.duty);
break;
case PWM_MODE:
long long us = PWM_PARAMS.microseconds;
long us_big = (long)((long long)us / (long long)1000);
long us_small = (us % 1000) / 10;
// example: ">100p 1.23ms"
snprintf(buf, sizeof(buf), "%s%dp %s%d.%02dms ",
p0_marker, PWM_PARAMS.pulses,
p1_marker, (int)us_big, (int)us_small);
break;
default:
snprintf(buf, sizeof(buf), "b %s%d p %s%l ",
p0_marker, button, p1_marker, PARAM_NUM);
lcd.setCursor(0,1);
lcd.print(buf);
/* save settings to eeprom
FIXME: This should be refactored together with the load_settings, as they're
basically the same function, just opposite directions */
void save_settings(bool immediate)
if (! immediate) {
lcd.setCursor(0,0);
lcd.print("Saving settings ");
lcd.setCursor(0,1);
lcd.print(" ");
delay(5000);
/* order:
int leak_test.seconds
int rpm_mode.seconds
short rpm_mode.duty
int rpm_mode.rpm
int full_flow.seconds
int pwm_mode.pulses
long long pwm_mode.microseconds
int eadr = 0;
/* leak test */
EEPROM.put(eadr, LEAK_TEST_PARAMS.seconds);
eadr += sizeof(LEAK_TEST_PARAMS.seconds);
/* rpm mode */
EEPROM.put(eadr, RPM_MODE_PARAMS.seconds);
eadr += sizeof(RPM_MODE_PARAMS.seconds);
EEPROM.put(eadr, RPM_MODE_PARAMS.duty);
eadr += sizeof(RPM_MODE_PARAMS.duty);
EEPROM.put(eadr, RPM_MODE_PARAMS.rpm);
eadr += sizeof(RPM_MODE_PARAMS.rpm);
/* full flow mode */
EEPROM.put(eadr, FULL_FLOW_PARAMS.seconds);
eadr += sizeof(FULL_FLOW_PARAMS.seconds);
/* pwm mode */
EEPROM.put(eadr, PWM_PARAMS.pulses);
eadr += sizeof(PWM_PARAMS.pulses);
EEPROM.put(eadr, PWM_PARAMS.microseconds);
eadr += sizeof(PWM_PARAMS.microseconds);
/* load settings from eeprom
FIXME: merge with save_settings */
void load_settings()
lcd.setCursor(0,0);
lcd.print("Loading settings ");
lcd.setCursor(0,1);
lcd.print(" ");
delay(1000);
/* order:
short rpm_mode.duty
int rpm_mode.rpm
int pwm_mode.pulses
int eadr = 0;
/* leak test */
EEPROM.get(eadr, LEAK_TEST_PARAMS.seconds);
/* rpm mode */
EEPROM.get(eadr, RPM_MODE_PARAMS.seconds);
EEPROM.get(eadr, RPM_MODE_PARAMS.duty);
EEPROM.get(eadr, RPM_MODE_PARAMS.rpm);
EEPROM.get(eadr, FULL_FLOW_PARAMS.seconds);
/* pwm mode */
EEPROM.get(eadr, PWM_PARAMS.pulses);
EEPROM.get(eadr, PWM_PARAMS.microseconds);
/* From the LCD analog signal, figure out the button pressed */
int get_button()
int x = analogRead (0);
if (x < 60) {
return RIGHT;
else if (x < 200) {
return UP;
else if (x < 400){
return DOWN;
else if (x < 600){
return LEFT;
else if (x < 800){
return SELECT;
return NO_BUTTON;
/* Functions to modify and bound the parameters to their specific ranges.
FIXME: This could probably be written as one function that uses pointers to
the variables instead.. */
void leak_test_change_param(int p, bool increase)
int modifier = increase ? 1 : -1;
LEAK_TEST_PARAMS.seconds += modifier * LEAK_TEST_PARAMS.second_step;
LEAK_TEST_PARAMS.seconds = LEAK_TEST_PARAMS.seconds > LEAK_TEST_PARAMS.max_seconds ? LEAK_TEST_PARAMS.max_seconds : LEAK_TEST_PARAMS.seconds;
LEAK_TEST_PARAMS.seconds = LEAK_TEST_PARAMS.seconds < LEAK_TEST_PARAMS.min_seconds ? LEAK_TEST_PARAMS.min_seconds : LEAK_TEST_PARAMS.seconds;
void full_flow_mode_change_param(int p, bool increase)
FULL_FLOW_PARAMS.seconds += modifier * FULL_FLOW_PARAMS.second_step;
FULL_FLOW_PARAMS.seconds = FULL_FLOW_PARAMS.seconds > FULL_FLOW_PARAMS.max_seconds ? FULL_FLOW_PARAMS.max_seconds : FULL_FLOW_PARAMS.seconds;
FULL_FLOW_PARAMS.seconds = FULL_FLOW_PARAMS.seconds < FULL_FLOW_PARAMS.min_seconds ? FULL_FLOW_PARAMS.min_seconds : FULL_FLOW_PARAMS.seconds;
void rpm_mode_change_param(int p, bool increase)
switch (p) {
case 0:
// seconds
RPM_MODE_PARAMS.seconds += modifier * RPM_MODE_PARAMS.second_step;
RPM_MODE_PARAMS.seconds = RPM_MODE_PARAMS.seconds > RPM_MODE_PARAMS.max_seconds ? RPM_MODE_PARAMS.max_seconds : RPM_MODE_PARAMS.seconds;
RPM_MODE_PARAMS.seconds = RPM_MODE_PARAMS.seconds < RPM_MODE_PARAMS.min_seconds ? RPM_MODE_PARAMS.min_seconds : RPM_MODE_PARAMS.seconds;
break;
case 1:
// RPM
RPM_MODE_PARAMS.rpm += modifier * RPM_MODE_PARAMS.rpm_step;
RPM_MODE_PARAMS.rpm = RPM_MODE_PARAMS.rpm > RPM_MODE_PARAMS.max_rpm ? RPM_MODE_PARAMS.max_rpm : RPM_MODE_PARAMS.rpm;
RPM_MODE_PARAMS.rpm = RPM_MODE_PARAMS.rpm < RPM_MODE_PARAMS.min_rpm ? RPM_MODE_PARAMS.min_rpm : RPM_MODE_PARAMS.rpm;
break;
case 2:
// duty
RPM_MODE_PARAMS.duty += modifier * RPM_MODE_PARAMS.duty_step;
RPM_MODE_PARAMS.duty = RPM_MODE_PARAMS.duty > RPM_MODE_PARAMS.max_duty ? RPM_MODE_PARAMS.max_duty : RPM_MODE_PARAMS.duty;
RPM_MODE_PARAMS.duty = RPM_MODE_PARAMS.duty < RPM_MODE_PARAMS.min_duty ? RPM_MODE_PARAMS.min_duty : RPM_MODE_PARAMS.duty;
break;
void pwm_mode_change_param(int p, bool increase)
switch (p) {
case 0:
// pulses
PWM_PARAMS.pulses += (increase ? 1 : -1 ) * PWM_PARAMS.pulse_step;
PWM_PARAMS.pulses = PWM_PARAMS.pulses > PWM_PARAMS.max_pulses ?
PWM_PARAMS.max_pulses : PWM_PARAMS.pulses;
PWM_PARAMS.pulses = PWM_PARAMS.pulses < PWM_PARAMS.min_pulses ?
PWM_PARAMS.min_pulses : PWM_PARAMS.pulses;
break;
case 1:
// microseconds
PWM_PARAMS.microseconds += (increase ? 1 : -1 ) * PWM_PARAMS.microsecond_step;
PWM_PARAMS.microseconds = PWM_PARAMS.microseconds > PWM_PARAMS.max_microseconds ? PWM_PARAMS.max_microseconds : PWM_PARAMS.microseconds;
PWM_PARAMS.microseconds = PWM_PARAMS.microseconds < PWM_PARAMS.min_microseconds ?
PWM_PARAMS.min_microseconds : PWM_PARAMS.microseconds;
break;
/* Calculate how many microseconds a 720 cycle lasts at a certain RPM */
long calculate_720_time_us(int rpm)
float t = 60.0 / ( (float)rpm / 2); // how long one 720 degree cycle lasts
return (long)(t * 1000000L);
/* Calculate how many microseconds the injector should be open to achieve a particular
duty cycle at a particular RPM */
long calculate_injector_open_time_us(int rpm, int duty)
return (duty * calculate_720_time_us(rpm))/100;
/* Sleep for longer than 16384 microseconds... Will blow the stack up at long delays (because no
* tail recursion) */
void do_longer_delay(long long microseconds)
if (microseconds > 16383) {
delayMicroseconds(16383);
do_longer_delay(microseconds - 16383);
} else {
delayMicroseconds(microseconds);
void do_constant_rpm_mode()
int rpm = RPM_MODE_PARAMS.rpm;
int duty = RPM_MODE_PARAMS.duty;
int seconds = RPM_MODE_PARAMS.seconds;
long cycle_720_time = calculate_720_time_us(rpm);
long injector_open_time = calculate_injector_open_time_us(rpm, duty);
long injector_close_time = cycle_720_time - injector_open_time;
char buf[100];
snprintf(buf, sizeof(buf), "cycle_720_time: %ld, open_time = %ld, close_time = %ld, "
"rpm = %d, duty = %d", cycle_720_time, injector_open_time, injector_close_time, rpm, duty);
Serial.println(buf);
snprintf(buf, sizeof(buf), "IPW: %ld.%ldms ", injector_open_time / 1000L, (long)(injector_open_time % 1000L));
snprintf(buf, 17, "IPW: %ld.%ldms ", injector_open_time / 1000L, (long)(injector_open_time % 1000L));
lcd.setCursor(0,0);
lcd.print(buf);
/* Turn on fuel pump */
digitalWrite(pin_FUEL_PUMP_RELAY, LOW);
delay(2000); // wait for 2s for stuff to stabilize
/* open for the first interval */
long start_time = micros();
long end_time = start_time + (long)(seconds * 1000000L);
snprintf(buf, sizeof(buf), "start time: %ld, end_time = %ld", start_time, end_time);
Serial.println("waiting");
/* Do the actual injector pulsing */
uint8_t pin_ALL_INJECTORS_MASK = pin_INJECTOR_1_MASK | pin_INJECTOR_2_MASK |
pin_INJECTOR_3_MASK | pin_INJECTOR_4_MASK;
do {
/* turn on */
PORTB = PORTB | pin_ALL_INJECTORS_MASK;
do_longer_delay(injector_open_time);
/* turn off */
PORTB = PORTB & (~pin_ALL_INJECTORS_MASK);
do_longer_delay(injector_close_time);
} while (end_time > micros()); // FIXME: What if end_time overflowed? This will run for a long time then...
Serial.println("done");
/* Turn off fuel pump */
digitalWrite(pin_FUEL_PUMP_RELAY, HIGH);
/* In Leak test mode, we simply run the fuel pump for n seconds */
void do_leak_test_mode()
int seconds = LEAK_TEST_PARAMS.seconds;
char buf[100];
snprintf(buf, sizeof(buf), "Leak test mode: Running pump for %d seconds", seconds);
/* Record start and end-times. Should probably check for overflow in the end_time variable
and handle that case */
// FIXME: Handle overflowing end_time
/* Now wait, and update the display every second */
do {
snprintf(buf, sizeof(buf), "%ds left ", (end_time - micros())/1000000L);
lcd.setCursor(0,1);
lcd.print(buf);
/* In full flow mode, we run the pump and open the injectors completely for n seconds */
void do_full_flow_mode()
int seconds = FULL_FLOW_PARAMS.seconds;
char buf[100];
snprintf(buf, sizeof(buf), "Full flow mode: full flow for %d seconds", seconds);
delay(2000); // wait for 2 seconds for fuel pressure to stabilize
/* Turn on injectors */
do {
lcd.setCursor(0,1);
lcd.print(buf);
/* Turn off fuel pump and injectors */
void do_pwm_mode()
long long int pulsewidth = PWM_PARAMS.microseconds;
long pulses = PWM_PARAMS.pulses;
char buf[100];
snprintf(buf, sizeof(buf), "PWM mode: pulsewidth = %ld us, number of pulses %d", pulsewidth, pulses);
Serial.println("after fuel pump");
/* pulse injectors */
for (int p = 0; p < pulses; p++) {
/* idea is: turn injector on, sleep for some time, turn off. Then delay some time until starting again */
/* turn on */
delayMicroseconds(pulsewidth);
/* turn off */
/* tell user how many to go */
snprintf(buf, 17, "pulses left %d ", pulses - p);
lcd.setCursor(0, 0);
lcd.println(buf);
delay(500);
lcd.begin(16, 2);
/* Check if select button is held down when powering up.
If it is, restore "factory defaults", otherwise load settings
from EEPROM */
int x = analogRead(0);
if (x >= 600 && x < 800) {
// pressed SELECT
lcd.setCursor(0,0);
lcd.print("RESETTING ");
lcd.setCursor(0,1);
lcd.print(" ");
delay(3000);
save_settings(true);
load_settings();
/* Enable serial port */
Serial.begin(9600);
/* Make fuel pump relay pin (22) an output and turn it HIGH (relay is off) */
pinMode(pin_FUEL_PUMP_RELAY, OUTPUT);
/* Make injector pins outputs */
DDRB = DDRB | dir_INJECTORS_OUT;
set_top_line(CURRENT_MODE);
set_bottom_line(CURRENT_MODE, NO_BUTTON);
/* check for button presses */
button_t button = (button_t)get_button();
if (LAST_BUTTON == button) {
if (button == UP || button == DOWN) {
/* user holding up / down button down? */
unsigned long now = micros(); // time now
unsigned long threshold = 300000; // threshold to generate another key press
if ((CURRENT_MODE == PWM_MODE && PARAM_NUM == 1) ||
(CURRENT_MODE == RPM_MODE && PARAM_NUM == 2)) {
/* in PWM mode, adjust the ms parameter quicker, and in RPM mode
adjust the duty quicker */
threshold = 100000;
if ((now - last_button_press_time) > threshold) {
/* button timeout - fake that the user let go of the button
by setting LAST_BUTTON to NO_BUTTON and re-running loop() */
return;
else if (button == SELECT) {
/* Save settings if select held for 1s continuously */
unsigned long threshold = 1000000; // threshold to save settings
save_settings(false);
else if (LAST_BUTTON != button) {
LAST_BUTTON = button;
/* record timestamp of button being pressed */
last_button_press_time = micros();
/* Change mode */
CURRENT_MODE = (operation_t)((int)CURRENT_MODE + 1);
if (CURRENT_MODE == NO_MODE) {
PARAM_NUM = 0;
else if (button == LEFT) {
/* Set param number */
switch(CURRENT_MODE) {
case LEAK_TEST:
PARAM_NUM = 0;
break;
case RPM_MODE:
PARAM_NUM = (PARAM_NUM + 1) % 3;
break;
case PWM_MODE:
PARAM_NUM = (PARAM_NUM + 1) % 2;
break;
default:
PARAM_NUM = 0;
else if (button == UP || button == DOWN) {
bool increase = button == UP;
/* increase/decrease parameter PARAM_NUM */
switch (CURRENT_MODE) {
case LEAK_TEST:
leak_test_change_param(PARAM_NUM, increase);
break;
full_flow_mode_change_param(PARAM_NUM, increase);
break;
case RPM_MODE:
rpm_mode_change_param(PARAM_NUM, increase);
break;
case PWM_MODE:
pwm_mode_change_param(PARAM_NUM, increase);
break;
else if (button == RIGHT) {
/* Run the tests */
case RPM_MODE:
do_constant_rpm_mode();
break;
case LEAK_TEST:
do_leak_test_mode();
break;
do_full_flow_mode();
break;
case PWM_MODE:
do_pwm_mode();
break;
/* Finally, update the bottom status line */
set_bottom_line(CURRENT_MODE, button);
#include <EEPROM.h>
#include <string.h>
#include <stdio.h>
int seconds;
int max_seconds;
int min_seconds;
int second_step;
} leak_test_params;
typedef struct {
int seconds;
int max_seconds;
int min_seconds;
int second_step;
short duty;
int duty_step;
int min_duty;
int max_duty;
int rpm;
int rpm_step;
int min_rpm;
int max_rpm;
} rpm_mode_params;
typedef struct {
int seconds;
int max_seconds;
int min_seconds;
int second_step;
} full_flow_params;
typedef struct {
int pulses;
int max_pulses;
int min_pulses;
int pulse_step;
} pwm_params;
typedef enum {
LEAK_TEST,
RPM_MODE,
FULL_FLOW_MODE,
PWM_MODE,
NO_MODE
} operation_t;
typedef enum {
NORMAL_MODE,
IN_MENU_MODE,
NO_STATE
} state_t;
NO_BUTTON,
LEFT,
RIGHT,
UP,
DOWN,
SELECT
} button_t;
modifiable */
int PARAM_NUM = 0;
.max_seconds = 300,
.min_seconds = 10,
.max_seconds=60,
.min_seconds = 5,
.second_step = 1,
.duty = 50,
.duty_step = 1,
.min_duty=1,
.max_duty=99,
.rpm = 1000,
.rpm_step = 200,
.min_rpm = 600,
.max_rpm = 6000 };
.max_seconds = 30,
.min_seconds = 1,
.second_step = 1 };
.max_pulses = 100,
.min_pulses = 1,
.pulse_step = 1,
/* User interface:
* Test modes:
* Leak test:
* RPM mode:
* Full flow mode:
* PWM mode:
char buf[17];
switch(mode) {
case LEAK_TEST:
break;
case RPM_MODE:
break;
break;
case PWM_MODE:
break;
default:
lcd.setCursor(0,0);
lcd.print(buf);
char buf[17];
switch (mode) {
case LEAK_TEST:
break;
break;
case RPM_MODE:
break;
case PWM_MODE:
break;
default:
lcd.setCursor(0,1);
lcd.print(buf);
if (! immediate) {
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" ");
delay(5000);
/* order:
short rpm_mode.duty
int rpm_mode.rpm
int pwm_mode.pulses
int eadr = 0;
/* leak test */
/* rpm mode */
/* pwm mode */
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" ");
delay(1000);
/* order:
short rpm_mode.duty
int rpm_mode.rpm
int pwm_mode.pulses
int eadr = 0;
/* leak test */
/* rpm mode */
/* pwm mode */
int get_button()
if (x < 60) {
return RIGHT;
else if (x < 200) {
return UP;
else if (x < 400){
return DOWN;
else if (x < 600){
return LEFT;
else if (x < 800){
return SELECT;
return NO_BUTTON;
switch (p) {
case 0:
// seconds
break;
case 1:
// RPM
break;
case 2:
// duty
break;
switch (p) {
case 0:
// pulses
break;
case 1:
// microseconds
break;
} else {
char buf[100];
lcd.setCursor(0,0);
lcd.print(buf);
do {
/* turn on */
/* turn off */
char buf[100];
do {
lcd.setCursor(0,1);
lcd.print(buf);
char buf[100];
do {
lcd.setCursor(0,1);
lcd.print(buf);
void do_pwm_mode()
char buf[100];
/* turn on */
/* turn off */
lcd.println(buf);
delay(500);
lcd.begin(16, 2);
from EEPROM */
// pressed SELECT
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(" ");
delay(3000);
load_settings();
Serial.begin(9600);
threshold = 100000;
return;
/* Change mode */
PARAM_NUM = 0;
case LEAK_TEST:
PARAM_NUM = 0;
break;
case RPM_MODE:
break;
case PWM_MODE:
break;
default:
PARAM_NUM = 0;
case LEAK_TEST:
break;
break;
case RPM_MODE:
break;
case PWM_MODE:
break;
/* Run the tests */
case RPM_MODE:
break;
case LEAK_TEST:
break;
break;
case PWM_MODE:
do_pwm_mode();
break;
