Forum >Firmware update (windows - failure
HUSKYLENSGeneral
userHead Account cancelled 2020-07-09 07:10:10 2932 Views3 Replies
I followed the instructions on the wiki to update the firmware and the camera does not turn on following the update (https://wiki.dfrobot.com/HUSKYLENS_V1.0 ... 6#target_6).
The camera worked prior to the update. Would you please provide a solution to the problem?
2020-07-11 03:02:23 There may be an interruption during the firmware update, resulting in an exception, you can try to update the firmware again.
In addition, how long did the process of updating the firmware last? About 5 minutes is normal.
userHeadPic Youyou
