Forum >Is it posible to extend the cable of the Throw-in Type Liquid Level Transmitter?
ArduinoHow to select
userHead Account cancelled 2020-07-12 13:59:16 1273 Views2 Replies
Hi, I need to install a Throw-in Type Liquid Level Transmitter in a tank, but I need to extend the cable ir order to plug it to my arduino in a place with power. I need to extend the cable 25 meters, so I need to know if by doing this the readings would be affected, and also, if it is possible to extend the cable, could you please tell me wich type of cable should I use.
2022-05-10 07:25:45
Good day DFROBOT - I think mariosilvestre2002 is not asking about replacing the sensor's cable but rather extending it. I have the same question; The cable that comes with the sensor is 5 meters long, but what if you wanted to add several meters of cable onto this 5 meter length ? can this be done and if so, what cable should be used and what voltage power supply should be used ? I see the sensor is rated 12V to 36V - so I bought a 24V power supply - how far can you extended the sensor cable with a 24V PSU ?
userHeadPic GarySwartz
