Forum >Dissolve oxygen sensor with Raspberry pi
I am using Dissolve oxygen analog sensor with Raspberry pi. But only I can read the voltage, and I was unable to add the equation to convert voltage in to mg.
Does anyone use Dissolve oxygen analog sensor with Raspberry pi?
Please kindly share the code if possible.
Thank you
niro
Thank you
niro
2020-09-10 02:14:20 Please see the section of calibration principle.
https://wiki.dfrobot.com/Gravity__Analo ... 7#target_4.
You can get the relationship between voltage and dissolved oxygen through actual test.
Youyou
2020-09-07 19:54:13 Hi Wang,
Any update about the codes for Dissolve oxygen sensor with raspberry pi??
Thank you!
Niro
niroshansnj
Thank you!
Niro
