DFPlayer Mini autostart (auto reset ?)
userHead Account cancelled 2020-08-11 21:44:41 1285 Views1 Replies
I recently bought a DFPLayer mini to use it as a nightlight for children with an ATtiny85 and despite a very simple code,
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
#define TXPIN   1
#define RXPIN   4
#define SERIAL  9600
#define VOLUME  10
#define TIMEOUT 500
SoftwareSerial mySoftwareSerial(RXPIN, TXPIN);
DFRobotDFPlayerMini myDFPlayer;
  mySoftwareSerial.begin(SERIAL);
  if (!myDFPlayer.begin(mySoftwareSerial)) {
    while (true);
  myDFPlayer.setTimeOut(TIMEOUT);
  myDFPlayer.volume(VOLUME);
  myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
  myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
  myDFPlayer.enableLoopAll();
  myDFPlayer.start();
  delay(1800000); // Turn evrything off after 30 minutes
  myDFPlayer.disableLoopAll();
  myDFPlayer.pause();
  myDFPlayer.sleep();
The DFPlayer does not start correctly.
I used an arduino nano in ISP to program the Attiny85 and when the upload is complete it starts perfectly. But when I disconnect it, and I turn on the attiny85 in 5v nothing happens. I have to manually reset the attiny85 by putting PIN 1 on GND for 1 second. Now, I would like it to start when powering up.
Could someone please explain to me what I should do about this problem?
