Forum >[LP 2G/32GB rev2.0 Activated]-Windows not activated! Arduino led is ON every time!
LattePandaGeneral
userHead Castellano Pasquale 2017-05-31 12:29:23 5650 Views2 Replies
Hi Guys!
I have two problems with my LattePanda (rev 2.0 with the label "Activated" on the board).
1)Arduino Led after normal blink, remains ON all the time: I've tried to upload a sketch, but Arduino doesn't work.
2)After the first boot, I connected LP to Internet and then I tried to activate Windows without success.
I repeated the procedures after a reboot without success.
What can I do to solve these problems?
Thanks!
Pasquale
2017-06-06 00:19:24 Hi!
thanks for your answer!
I solved all the problems:
1)Windows is successfully activated using the tutorial
2)I upgraded the Arduino IDE(on the board is present the 1.0.6 version) with the latest version (1.8.2): after a reboot, i pressed the Arduino reset and the Arduino's drivers have been updated successfully. I uploaded a sketch and...now it works like a charm!
Thanks a lot!
Pasquale
userHeadPic Castellano Pasquale
2017-06-01 00:14:13 Hi!
all the boards in my last order have these problems(3/3 boards)! I tested it after one month because I purchased it as spare parts.
1)Windows is not activated because these boards(rev2.0) came with Windows 10 Home x64
2)I selected the Arduino Leonardo, the right COM port, but when I try to upload a sketch(blink), the Arduino COM port disappears and the upload fails. On one board the upload went successfully but when I tried to upload another sketch, this operation fails because the COM port disappears. When I reset the arduino, after blink, the led remains ON all the time.
I can try to install the x86 version but the Arduino's problem remains. Could be faulty units?
Thanks a lot!
Pasquale
