Forum >MicroSD Card Module for Arduino - DFR-0229
I am having trouble with the SD Card Module, every example code I use from the library provided on the product page does not work. I keep getting errors.
https://www.dfrobot.com/product-875.html
This error is from the example from SDInfo
card.init failed
SD errorCode: 0X1
SD errorData: 0X0
type any character to start
I am using an arduino Mega, Arduino IDE 1.8.13, using the library provided in the product page, SD Card is a samung EVO Plus 32GB formatted to FAT32 and formatted using the method by https://forum.arduino.cc/index.php?topic=228201.0
This product has a different pin layout compared to the generic micro sd card readers but I followed the product's wikipage https://wiki.dfrobot.com/MicroSD_card_m ... KU_DFR0229_
Please help. Code I used is below
card.init failed
SD errorCode: 0X1
SD errorData: 0X0
/* * This sketch attempts to initialize an SD card and analyze its structure. */ #include <SdFat.h> /* * SD chip select pin. Common values are: * * Arduino Ethernet shield, pin 4. * SparkFun SD shield, pin 8. * Adafruit SD shields and modules, pin 10. * Default SD chip select is the SPI SS pin. */ const uint8_t SdChipSelect = SS; Sd2Card card; SdVolume vol; // serial output steam ArduinoOutStream cout(Serial); // global for card size uint32_t cardSize; // global for card erase size uint32_t eraseSize; //------------------------------------------------------------------------------ // store error strings in flash #define sdErrorMsg(msg) sdErrorMsg_P(PSTR(msg)); void sdErrorMsg_P(const char* str) { cout << pgm(str) << endl; if (card.errorCode()) { cout << pstr("SD errorCode: "); cout << hex << int(card.errorCode()) << endl; cout << pstr("SD errorData: "); cout << int(card.errorData()) << dec << endl; } } //------------------------------------------------------------------------------ uint8_t cidDmp() { cid_t cid; if (!card.readCID(&cid)) { sdErrorMsg("readCID failed"); return false; } cout << pstr("\nManufacturer ID: "); cout << hex << int(cid.mid) << dec << endl; cout << pstr("OEM ID: ") << cid.oid[0] << cid.oid[1] << endl; cout << pstr("Product: "); for (uint8_t i = 0; i < 5; i++) { cout << cid.pnm[i]; } cout << pstr("\nVersion: "); cout << int(cid.prv_n) << '.' << int(cid.prv_m) << endl; cout << pstr("Serial number: ") << cid.psn << endl; cout << pstr("Manufacturing date: "); cout << int(cid.mdt_month) << '/'; cout << (2000 + cid.mdt_year_low + 10 * cid.mdt_year_high) << endl; cout << endl; return true; } //------------------------------------------------------------------------------ uint8_t csdDmp() { csd_t csd; uint8_t eraseSingleBlock; if (!card.readCSD(&csd)) { sdErrorMsg("readCSD failed"); return false; } if (csd.v1.csd_ver == 0) { eraseSingleBlock = csd.v1.erase_blk_en; eraseSize = (csd.v1.sector_size_high << 1) | csd.v1.sector_size_low; } else if (csd.v2.csd_ver == 1) { eraseSingleBlock = csd.v2.erase_blk_en; eraseSize = (csd.v2.sector_size_high << 1) | csd.v2.sector_size_low; } else { cout << pstr("csd version error\n"); return false; } eraseSize++; cout << pstr("cardSize: ") << 0.000512*cardSize; cout << pstr(" MB (MB = 1,000,000 bytes)\n"); cout << pstr("flashEraseSize: ") << int(eraseSize) << pstr(" blocks\n"); cout << pstr("eraseSingleBlock: "); if (eraseSingleBlock) { cout << pstr("true\n"); } else { cout << pstr("false\n"); } return true; } //------------------------------------------------------------------------------ // print partition table uint8_t partDmp() { cache_t *p = vol.cacheClear(); if (!p) { sdErrorMsg("cacheClear failed"); return false; } if (!card.readBlock(0, p->data)) { sdErrorMsg("read MBR failed"); return false; } cout << pstr("\nSD Partition Table\n"); cout << pstr("part,boot,type,start,length\n"); for (uint8_t ip = 1; ip < 5; ip++) { part_t *pt = &p->mbr.part[ip - 1]; cout << int(ip) << ',' << hex << int(pt->boot) << ',' << int(pt->type); cout << dec << ',' << pt->firstSector <<',' << pt->totalSectors << endl; } return true; } //------------------------------------------------------------------------------ void volDmp() { cout << pstr("\nVolume is FAT") << int(vol.fatType()) << endl; cout << pstr("blocksPerCluster: ") << int(vol.blocksPerCluster()) << endl; cout << pstr("clusterCount: ") << vol.clusterCount() << endl; uint32_t volFree = vol.freeClusterCount(); cout << pstr("freeClusters: ") << volFree << endl; float fs = 0.000512*volFree*vol.blocksPerCluster(); cout << pstr("freeSpace: ") << fs << pstr(" MB (MB = 1,000,000 bytes)\n"); cout << pstr("fatStartBlock: ") << vol.fatStartBlock() << endl; cout << pstr("fatCount: ") << int(vol.fatCount()) << endl; cout << pstr("blocksPerFat: ") << vol.blocksPerFat() << endl; cout << pstr("rootDirStart: ") << vol.rootDirStart() << endl; cout << pstr("dataStartBlock: ") << vol.dataStartBlock() << endl; if (vol.dataStartBlock() % eraseSize) { cout << pstr("Data area is not aligned on flash erase boundaries!\n"); cout << pstr("Download and use formatter from www.sdcard.org/consumer!\n"); } } //------------------------------------------------------------------------------ void setup() { Serial.begin(9600); while(!Serial) {} // wait for Leonardo // use uppercase in hex and use 0X base prefix cout << uppercase << showbase << endl; // pstr stores strings in flash to save RAM cout << pstr("SdFat version: ") << SD_FAT_VERSION << endl; } //------------------------------------------------------------------------------ void loop() { // read any existing Serial data while (Serial.read() >= 0) {} // pstr stores strings in flash to save RAM cout << pstr("\ntype any character to start\n"); while (Serial.read() <= 0) {} delay(400); // catch Due reset problem uint32_t t = millis(); // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with // breadboards. use SPI_FULL_SPEED for better performance. if (!card.init(SPI_HALF_SPEED, SdChipSelect)) { sdErrorMsg("\ncard.init failed"); return; } t = millis() - t; cardSize = card.cardSize(); if (cardSize == 0) { sdErrorMsg("cardSize failed"); return; } cout << pstr("\ninit time: ") << t << " ms" << endl; cout << pstr("\nCard type: "); switch (card.type()) { case SD_CARD_TYPE_SD1: cout << pstr("SD1\n"); break; case SD_CARD_TYPE_SD2: cout << pstr("SD2\n"); break; case SD_CARD_TYPE_SDHC: if (cardSize < 70000000) { cout << pstr("SDHC\n"); } else { cout << pstr("SDXC\n"); } break; default: cout << pstr("Unknown\n"); } if (!cidDmp()) return; if (!csdDmp()) return; if (!partDmp()) return; if (!vol.init(&card)) { sdErrorMsg("\nvol.init failed"); return; } volDmp(); }
