Forum >Unstable Output Analog Current to Voltage Converter SKU SEN0262
TroubleshootingGravity
userHead vasconinicolas 2020-10-09 05:13:50 2868 Views4 Replies
2023-01-27 20:13:32
Hi. I'm having the same issue. One thing i have noticed is i'm using a step uppower supply from 3.3v to 12v. Once i connect the + lead in to the  SEN0262 i start registering current even tho the - lead is unconnected. I think the current it looping back through the ESP32 to the common power supply. Is there a way to stop this or filter it out?
I have a SEN0262 connected to the 16-Bit ADC connected to the ESP32. If i remove the + lead the sensor drops back to 0v 0ma as expected.
Andrew
userHeadPic Andrew.Paternoster
2022-04-19 04:43:42
Please describe your scenarino with more detail.  That will help us to identify the problem.
userHeadPic R2D2C3PO
2022-04-15 22:08:32
Me Too. I have several of these all doing th same thing. Creates a real problem. Have been trying to get to the solution for this since Jan 2022 (Now April).
userHeadPic KevinPearce
2020-10-09 13:31:19 I have bought several converters from DFRobot, so it is not a problem on a particular board. In all I see the same phenomenon. Any DFRobot ideas? userHeadPic vasconinicolas
