Forum >FIT0441 Gear Ratio
RoboticsGeneral
FIT0441 Gear Ratio
userHead honoka 2020-10-16 12:37:26 2087 Views0 Replies
I would like to ask if FIT0441 is available in other gear ratios. I would need a roughly 5 or 10 RPM output.
If you can't supply one, would one of these work for gearbox swap?
https://www.aliexpress.com/item/4000765323230.html
//Kind regards.
