Forum >Using Gravity LCD with Teensy 3.6
I'm having trouble getting the Gravity LCD to work with a Teensy 3.6.
It compiles fine but the LCD is showing no output.
One problem may be that I'm using the 2nd I2C bus on the board SCL1.
Can anybody point me in the right direction about what needs to be changed in order to get this to work?
Kind regards,
Kind regards,
2020-11-03 06:07:43 Anyone?
Else is it possible to share the instrucion set so I can use regular I2C to connect to it?
lukasblersch
