Forum >Re: SIM7600 SOFTWARE POWER ON
userHead 347945801 2020-11-19 22:34:20 2722 Views6 Replies
You can set the pin to high/low to turn the module on/off with code.
But you need to set the pin to high for a period of time (maybe 2-3 seconds), so that you can open the module normally
2021-01-26 02:13:12 AT commands are compatible with SIM7500/SIM7600-H series modules. Meanwhile the SIM7600 series integrates main industrial standard interfaces, with powerful expansibility, including abundant interfaces such as UART, USB, I2C, GPIO, which is suitable for main IoT applications such as telematics, surveillance devices, CPE, industrial routers, and remote diagnostics etc! userHeadPic donaldmontgo82
2020-11-24 02:01:45 Thanks for the information.Keep sharinglike this.
mygiftcardsite
userHeadPic melodygeorge178
