Forum >DFR0534 VOICE MODULE
userHead Account cancelled 2020-11-15 22:32:50 7938 Views2 Replies
Please provide info on how to connect this to the Microbit and code samples.
Also the DFR0440. Thanks.
2021-09-10 23:19:47 WorldEscortsHub - Minneapolis Escorts, St. Paul Escorts - Female Escorts - Local Escorts In Minnesota. userHeadPic worldescortshub
2020-12-04 18:43:50 I don't know if you need an example of makecode or Arduino. So I give you the easiest way I know is to download Mind+
http://mindplus.cc/en.html
You can find micro:bit and MP3 in the graphical programming components above
DFR0440 can be similar to motor drive, you can still find a solution in Mind+
userHeadPic 347945801
