Forum >FIT0441 Dimension L???
RoboticsGeneral
userHead Account cancelled 2020-11-25 07:08:15 3699 Views2 Replies
The page does not give any value for dimension L
I need to know the actual dimensions of the motor!
https://wiki.dfrobot.com/FIT0441_Brushl ... 12V_159RPM
2020-11-26 17:33:59 L is the length of the reduction gearbox, which is determined according to the reduction ratio
The default value is 21mm
userHeadPic 347945801
2020-11-26 17:27:24 L is the length of the reduction gearbox, which is determined according to the reduction ratio
