Forum >Object Classification
I have uploaded 0.4.9Class firmware from the Github and tried to train 3 different objects using a white paper as background.
When I finish the training Huskylens can recognize the 3 objects and differentiate them - Nice!
But whenever I point Huskylens at an area (eg wodden table or the white paper) with none of the 3 objects it will still display eg Object:ID1 or 2 on the screen.
Could you share how you did the training of the gestures in a tutorial?
Cheers, Gernot
Cheers, Gernot
2021-02-26 20:07:46
Please, this is normal ?. Even if i point to a white paper?.
danielmeireles
I got this behavior after use the object classification, the Huskylens still show Object:ID1 on screen.geab wrote:I have uploaded 0.4.9Class firmware from the Github and tried to train 3 different objects using a white paper as background.
Cheers, Gernot
2021-01-23 00:01:39 You can find routines and methods in this area on Mind+
http://mindplus.cc/en.html
347945801
