Forum >URM09 analog inconsistent readings
I have four URM09 analog sensors mounted on my robot and experiencing issue with inconsistent readings from one of them. It will report expected distance for few seconds, but then will reset and report some random measurements ranging from close to 0 to expected difference before recovering back to expected distance. Is it typical for this kind of sensors or there is something about my robot or environment that I need to take into consideration?
2020-12-19 02:46:37 You can check your connection and code. If you are sure that there is no error and the sensor is still inaccurate, you can contact our customer service and apply for after-sales service
347945801
