Forum >TS01 Non-contact IR Temperature Sensor 0-3V
I'm designing an IR camera based on this sensor; can you tell me what wavelengths of IR it uses? (So I can choose an appropriate mirror material).
2021-01-22 23:48:56 This sensor should not emit infrared signals, it measures temperature by receiving infrared signals, and it should not be able to determine the wavelength of the signal
347945801
