Forum >SEN0220 for RaspberryPI
userHead Account cancelled 2021-02-06 05:08:35 879 Views1 Replies
Does anyone have experience connecting the SEN0220 to a Raspberry PI? I would like to write and compile a python program to get the sensor readings, similar to the sample code for arduino posted in the wiki.
Thanks for any help
2021-02-07 21:58:13 If you use the soft serial port of the Raspberry Pi, you need to install the pyserial module in your operating system. This requires you to learn by yourself, and I cannot help you. If you need to read analog values, you need to use an ADC converter to read digital information userHeadPic 347945801
