Forum >Huskylens failed firmware update - now "bricked"
HUSKYLENSGeneral
userHead stevegale54 2021-04-01 10:02:48 4526 Views2 Replies
I finally decided to use my Huskylens, it has been sitting on a shelf since it arriced as part of the Kickstarted, the plan was to connect it to a PICO.
I followed the instructions and attempted to update the firmware.
The output i sshown below:
:~/HUSKYLENSUploader-master $ sudo python3 kflash.py HUSKYLENSWithModelV0.5.1Norm.kfpkg
[INFO] COM Port Auto Detected, Selected /dev/ttyUSB0
[INFO] Default baudrate is 115200 , later it may be changed to the value you set.
[INFO] Trying to Enter the ISP Mode...
[INFO] Greeting Message Detected, Start Downloading ISP
Downloading ISP: |██████████████████████████████████████████████████| 100.0% Complete
[INFO] Booting From 0x80000000
[INFO] Wait For 0.3 second for ISP to Boot
[INFO] Boot to Flashmode Successfully
[INFO] Selected Flash: On-Board
[INFO] Extracting KFPKG ...
[INFO] Writing HuskyLens.bin into 0x00000000
Downloading: |████████████████████████████████████████----------| 80.5% Complete
I left it for over an hour stuck at 80.5%
Then disconnected and re-connected it to my computer, now there is no image displayed.
Is there anyway to recover the situation or is it irrecoverable?
Steve Gale
2021-04-02 03:26:44 No I was using Buster OS on my PI.
Once the initial panic died down Itried it again on my MAC and that all worked.
So I have a working huskylens again, now to connect it to my PICO.
Steve
userHeadPic stevegale54
2021-04-01 12:53:18 Hi There,
Did you tried the USB HuskyLens Uploader using Windows ?.
https://wiki.dfrobot.com/HUSKYLENS_V1.0 ... 6#target_5
[]'s
Daniel
userHeadPic danielmeireles
