Forum >Relay-8 stops responding
here is my issue, I have 2 relay-8 boxes on my network, after about 24 hours the two of them stop responding and it is almost at the exact same time. in trying to troubleshoot the issue I replaced the one gave it a new ip address and the same issue happened. the only common thing I can figure is that they are on the same vlan but besides that I can not come up with a relationship......thanks for any suggestions......HOSS
2021-05-13 21:11:36 The breadboards like yours usually have power rails separated in the middle. On a photo of your setup it looks like you connected your power supply to the upper half of the board, and reset of the circuit to the lower. Try connecting everything on the same half, or use jumpers to connect power rails.
patboyd199.6
2021-05-06 21:07:44 Found the solution. Change the digitalWrite from HIGH to LOW and LOW to HIGH for pin 7
naomiperez19886
Hope this help others for having same relay. void setup() { pinMode(7,OUTPUT); // Relay Signal Pin digitalWrite(7,LOW); // <-- change this digitalWrite(7,HIGH); // shutdown the circuit <-- change this too } void loop() { }
