Forum >ESP32-S2-Solo
ESP32-S2-Solo
With the ESP32-S2-Solo I would like to run a 0-12v battery powered dc motor with pwm. What motor amps will it handle without having to use a motor driver ? Need only 0.5 amp to 1 amp max.
Has someone out there got any circuits for using dc motor ?
Charles Harris
Charles Harris
2021-05-08 18:12:20 I think you can use it to output pwm signals, which can drive some simple motors and servos.
But many motors with encoders require professional motor drive boards.
347945801
