Forum >DFRobot PT100 gravity shield (SEN0198) with ESP32
userHead Account cancelled 2021-05-13 00:07:35 747 Views0 Replies
I've bought a Gravity: Analog High Temperature Sensor (SEN0198) with included a PT100 probe (https://wiki.dfrobot.com/HighTemperatur ... KU_SEN0198).
I'm trying to use it with an ESP32 with DFRobot library (https://raw.githubusercontent.com/nxcos ... raries.zip) and the results are far from correct.
At ambient temperature a DS18B20 is measuring 18-18.1 °C while the PT100 is measuring between 7 and 9°C.
In the code I select 3.3 V (same voltage as ESP32 output)
#include<DFRobotHighTemperatureSensor.h>
const float voltageRef = 3.300; //Set reference voltage,you need test your IOREF voltage.
Do you have any idea how to solve ?
Thanks a lot
