Forum >SHT10 connection issues
userHead Account cancelled 2021-05-27 03:21:41 660 Views0 Replies
I've recently purchased a SHT10 sensor. It finally arrived. ITs a DFROBOT part number SEN0148 made in china 2018.09.30 stainless steel probe.
on wht dfrobot wiki (Digital_Temperature_and_Humidity_sensor__With_Stainless_Steel_Probe___SKU_SEN0148_-DFRobot) it says that this is a SHT20 sensor... beeing a SHT20 its a 3.3volts sensor right ?
it needs the 3330ohm resistors on the SDA/SCL vcc on the 3v3 of the arduino.
So far so good.
But on the sensor i got a sticker saying : TYPE: DB130-10
SUPPLY: 2.5-5V output digital.
Now i am confused :
Cause if it is a STH10 its a 5 volts sensor and i need no resistors...
but if it is i will burn it if i connect it to 5 volts...
help ?
tanks
