Forum >DFRobot Beetle & MAX7219 8x8 Matrix wiring?
userHead Account cancelled 2021-06-13 07:37:45 430 Views0 Replies
Hey all - I'm trying to wire a MAX7219 kit to a DFRobot Beetle and I'm not sure I'm hooking things up correctly. From what I've read, this is what I have so far:
MAX7219 ===> Beetle
VCC ===> 5V
GND ===> GND
DIN ===> MOSI
CS ===> ?
CLK ===> SCK
I'm not sure where to wire CS on the Beetle.
• SKU:DFR0282
• Ardunio Leonardo (1.8.15)
• What is the intended function of your project?: Shifter gear display for IRL car.
• Are you using any libraries? Not fully decided yet, I'm running test code to make sure its wired properly and functioning, from https://lastminuteengineers.com/max7219 ... -tutorial/
Thanks for any help. I'm new to all this so go easy :)
