Forum >SEN0224 I2C Triple Axis Accelerometer
Using example diagram and code from the Wiki page:
https://wiki.dfrobot.com/Gravity__I2C_T ... KU_SEN0224
The example shows Green as SCL (A04) and Blue as SDA (A05).
The wiring harness that came with SEN0224, Blue is SCL and Green is SDA.
Failure to verify wiring will result in "No I2C Devices Found"
