Forum >SKU:DFR0767 CM4 Router Board -- Turn off LEDs
ArduinoTroubleshooting
userHead martin 2021-08-10 11:23:39 1095 Views1 Replies
Is it possible to turn off the LEDs on the Raspberry Pi CM4 Router Board from software? I have tried these settings (config.txt) which work on a standard RPi 4:
Code: Select all[pi4] # Disable the PWR LED dtparam=pwr_led_trigger=none dtparam=pwr_led_activelow=off # Disable the Activity LED dtparam=act_led_trigger=none dtparam=act_led_activelow=off
But that has no effect on the Router Board.
Currently I use black duct tape, but software would be a more elegant solution.
2022-08-12 00:50:26
The PWR and ACT indicators cannot be turned off by software.
userHeadPic jenna
