Forum >DF player sound problems
userHead Account cancelled 2017-06-24 01:05:20 1513 Views3 Replies
hello guys , i have DF player module
i use the arduino example code of DF player , i encounter a very strange problem
when i connect the DF player and upload code everyting works perfect !!
but when i disconnect the arduino and plug the power back again
The DF begin to output a very bad sound , so i try to unplug wires then plug it again for troubleshooting , after a while is start working again , but still the same problem if i pull the power then get it back again still i get crappy noise !!
2024-06-04 10:00:47
The grounds of all components (Arduino, DF player, power supply) should be connected together properly. A common ground is essential for proper operation, and not having it can cause noise issues.
userHeadPic lia.ifat
2017-06-27 02:22:15 Do you connect the resistance between the TX/RX pins as the wiki says userHeadPic robert.chen
Arzhang.Tahmosybayat wrote:
hi, can someone help - i have the same issue? I cant find a reference to the resistance instruction mentioned above?
2024-06-03 04:06:09
