What cable to use for DFPlayer Pro
The schematic for the DFPlayer Pro [SKU DFR0768] calls out a 25 pin connector "U1" which physically resembles a USB connector on the actual board.
https://dfimg.dfrobot.com/nobody/wiki/8 ... 912a05.pdf
(1) What interface is that connector? USB? But USB 2.0 Type A/B are 4 pin, Type C is 24 pin, Mini/Micro A/B are all 5 pin. IEEE 1284?
https://en.wikipedia.org/wiki/USB
https://en.wikipedia.org/wiki/IEEE_1284
(2) What cable do I need to load audio files to U4 flash memory? A DB25 adapter cable?
https://www.amazon.com/dp/B000UX21PY
(3) What software do I need on a Windows 10 platform?
2022-02-23 18:39:41 A styptic powder for cats is a styptic powder that can be used to stop bleeding from a cat's nail. The product is composed of a white powder that is without problems applied to the nail. The product is designed to forestall bleeding from a cat's nail and does no longer incorporate any substances that would damage the cat. herbalbiotechcoltd
2021-10-16 19:21:11 It looks like that U1 is a USB Type C with 24 pins + shell connection. Maybe a "USB C to USB Adapter" could be used for a system with USB Type A connector?
https://www.amazon.com/dp/B07BS8SRWH dgreenhoe
