Forum >Firebeetle ESP32 DFR0478 - Dimensions
userHead Account cancelled 2021-11-07 03:29:07 630 Views0 Replies
1) Dimensions. I want to stick the Firebeetle under an e-ink display and I'm a bit worried that the firebeetle might be to high. I was able to find one drwaing that says its 7mm at most, which is the JST jack. Is the 7mm accurate and if it is, is it possible to detatch the JST jack and just solder the battery on to the board? Does anyone have experiences with this? Also, how high will it be without the JST jack? I'm hoping its under 5mm
2) I should be able to control a e-ink display with a firebeetle right? Just making sure. :)
Thanks!
