Forum >Audio Connector Question
LattePandaGeneral
userHead Account cancelled 2017-06-26 23:06:42 2894 Views1 Replies
Hi All,
I need to know if the LattePanda's Audio connector supports both Audio out (to Speakers or is it line level - so requires Speakers to be amplified) and Microphone in.
If so does it need a TIP-RING-RING-SLEEVE 3.5mm jack and what are the pinouts/connections?
There is no detailed information regarding the Audio connector in any documentation for the LattePanda.
Thanks in advance
Paul
2017-07-25 07:02:33 The audio socket works with my Samsung Note 4 smartphone headset -> both speaker and microphone. I therefore conclude that you should be able to get a wiring diagram on the Internet somewhere
Using LattePanda 4GB board with Windows 10.
Tested audio with Skype
userHeadPic daniel.rueppel
