Forum >Chuwi Minibook Shuts off on LP Alpha
userHead Account cancelled 2021-12-02 03:52:27 1170 Views2 Replies
So I’m using a 6100 mah battery for a Latte Panda alpha powered handheld, but under high load (ie running pcsx2) the system shuts down after a few minutes. However, I’m able to reboot and continue using the system afterward without recharging. I’m running windows 10 and I’m connected to a 7 inch hdmi display. I think this may be due to excess current draw but am not sure. Is there anything I Tweakbox Appvalley https://vlc.onl
can do to prevent this from happening?
2022-05-08 03:43:17
Could you share the specification of your battery?
userHeadPic Youyou
2022-05-07 23:15:17
Hi there, what's the specification of your battery? what's the power output? It seems your battery cannot provide sufficient power to LattePanda.
userHeadPic Queenie.Le
