receiving sms's via dfrobot shield sim800H
userHead pawelung 2017-06-26 22:25:27 1679 Views2 Replies
I have a few questions about SMS service.
I want shield to receive sms, and if the SMS is send from my number, it should read the message, do something ang delete SMS. If the SMS is send from different number, ignore and delete.
Function from the library doesn't show the phone number, how can I do this with AT commands? Or can I use built-in GSM library?
How can I check, if there is a new SMS?
If there is an incoming SMS, is it automatically stored in memory?
I use Arduino mega 2560 and IDE 1.0.6
Sorry for my questions, I'm a noob.
2017-07-07 18:00:50 Thank you for your answer, another problem is recognition of SMS content, my code is:
Code: Select all
#include <sim800cmd.h>
Sim800Cmd sim800demo(fundebug);
const int LED=13;
char id[5]={'\0'};
char contents[21]={'\0'};
void setup(){
  pinMode(LED, OUTPUT);
  while((sim800demo.sim800init())==0);
  delay(1000);
  sim800demo.setSMSEnablePrompt(OPEN);
  sim800demo.setSMSHandlefunction(fundebug2);
  delay(1000);
void loop(){
void fundebug(void){
  sim800demo.cancelCall();
void fundebug2(void){
  sim800demo.getSMSID(id);
  sim800demo.readSMS(id,contents);
  if(contents=="TURN ON"){
    digitalWrite(LED, HIGH);
  } else if(contents=="TURN OFF"){
    digitalWrite(LED, LOW);
  sim800demo.deleteSMS(id);
Of course it doesn't work, but it compiles now. How can I fix it?
Ok, it turned out, that recieved massage is also in UCS2 code, and second thing is, that I should read it in main loop, not fundebug2 function.
userHeadPic pawelung
2017-07-04 15:47:19 We recently have change the library of this board, please download the latest library, we have use the following code to display the number in serial monitor
Code: Select all
//initialize the library instance
//fundebug is an application callback function,when someon is calling.
Sim800Cmd sim800demo(fundebug1);
//phone number buffer
char str[15] = {'\0'};
//the setup routine runs once when you press reset:
    //initialize the digital pin as an output.
    pinMode(13,OUTPUT);
    //initialize SIM800H,return 1 when initialize success.
    while((sim800demo.sim800init()) == 0);
    //enable SIM800H Modular Caller ID
    sim800demo.DisplayPhoneNumber(OPEN);
    Serial.begin(19200);
//the loop routine runs over and over again forever:
//application callback function
//Note that not too much to handle tasks in this function
void fundebug1(void)
  //get the phone number
  sim800demo.getCallnumber(str);
  for(int i=0; i<15; i++)
    Serial.print(str[i]);
    Serial.print("\n");
The AT command "AT+CLIP=1\r\n" can show the phone number. You can download the AT command manual for more functions
userHeadPic robert.chen
