Forum >Using OV5640 lens with Huskylens
HUSKYLENSGeneral
userHead aboss18 2021-12-25 12:40:59 1097 Views0 Replies
Is there a way to upgrade the standard OV2640 lens that comes with the Huskylens to OV5640. I bought one with the correct connection 24 pin same as the OV2640 but when the 5640 is plugged in the screen stays blank. Is there something on the software size that must be done to get it to work? I've also upgraded to the latest firmware as I read somewhere that the newer firmware supports OV5640. thanks.
