Forum >FIT0441 : Direction
RoboticsGeneral
FIT0441 : Direction
userHead cjiwan 2017-07-04 11:44:16 2569 Views5 Replies
I use for the first time the FIT0441.
I try to use it with a arduino uno and the sample programme shown on the wiki.
My problem is about the direction pin. When this pin is set to true, the motor turne. I can change the speed with the PWM output.
When the direction pin is set to false, the motor stop.
Have you some idea?
2017-07-14 10:42:51 Many Thanks. With your solution it works perfect.
Christian
userHeadPic cjiwan
2017-07-12 12:43:57 Ok, Thanks I try that and I keep you in touch. userHeadPic cjiwan
2017-07-12 01:44:22 You need to connect your Arduino GND to the negative of the power userHeadPic robert.chen
2017-07-08 11:10:58 No, the motor rotate in one direction 5sec, stop for 5 sec and restart. userHeadPic cjiwan
2017-07-07 21:37:45 If you upload the program on the wiki, did the motor rotate clockwise and count clockwise each 5 sec? userHeadPic robert.chen
