Forum >Huskylens camera ribbon length
HUSKYLENSGeneral
userHead aboss18 2022-01-22 07:19:47 434 Views0 Replies
Is there a limit to how long of a ribbon cable can be put on with the huskylens camera? I bought a 75mm and a 200mm ribbon length OV2640 cameras. When the 75mm ribbon is plugged in and the unit is turned on all is well and the view loads on the screen but when I plug in the 200mm ribbon length camera I just get a blank screen. The screen turns on but stays blank. I've tried with multiple cameras that are at the 200mm length and get the same result. Is there any way to make it work with a longer ribbon cable or is it a limitation that's built-in for some odd reason?
