SEN0188 stopped worked
![userHead](https://dfimg.dfrobot.com/dfPortrait2.png)
Hello everyone, I Bought SEN0188 sensor and I tried to use but its give error: "Did not find fingerprint sensor
". After some search and datasheet checking, I Finded error and updated "FINGERPRINT_VERIFYPASSWORD". After some usage and testing. I finished project, I put in the box and after some trying, I again getting to "Did not find fingerprint sensor
" again. I checked my code, wiring shematic and etc.. But doesnt working.
Library: github.com/adafruit/Adafruit-Fingerprint-Sensor-Library/
Code :
![Sad :(](./images/smilies/icon_e_sad.gif)
Code :
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
SoftwareSerial mySerial(2, 3);
#else
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Serial.begin(9600);
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit finger detect test");
finger.begin(57600);
while (true) {
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
break;
} else {
Serial.println("Did not find fingerprint sensor :(");
delay(1000);
void loop() {}
2023-01-17 14:18:18
jenna
This looks like a bad connection somewhere in the wiring. It is recommended to replace the wire, or use a multimeter to test the circuit.
![userHeadPic](https://dfimg.dfrobot.com/dfPortrait2.png)
