Forum >Documentation about DFR0528
TroubleshootingArduino
userHead Account cancelled 2022-01-30 00:24:10 1342 Views1 Replies
Hello!
Yesterday I received this DFR0528 Raspberry Pi UPS.
So, I don't understand this device complete.
Where I can find a documentation beside this:
https://wiki.dfrobot.com/UPS%20HAT%20fo ... 8#target_3
To understand it I need a block diagram, schematic, Pin assignment.
Does it has an steip regulator?
What is the charging current?
I have an problem regarding I2C:
I enabled I2C and install the package.
[email protected]:~ $ sudo i2cdetect -y l
Error: I2C bus name doesn't match any bus present!
Usage: i2cdetect [-y] [-a] [-q|-r] I2CBUS [FIRST LAST]
i2cdetect -F I2CBUS
i2cdetect -l
I2CBUS is an integer or an I2C bus name
If provided, FIRST and LAST limit the probing range.
Which component limits the current?
I want to use it on a Raspberry Pi4
Thank you.
