Forum >Devastator Robot doesnt turn
Ive tried changing the length of the tracks as when i try to turn the tank it either goes very very slowly or lets out a high pitch buzz. Im not sure how to make it turn with ease?
2018-01-13 17:18:19 There isn’t enough power in the circuit to drive the motors. I use an external wall power supply that fits the adapter intended to connect to the battery case. The adapter I use is 12VDC and is 2 Amps. 12VDC will move your tracks quite quickly. I don’t recommend going over 2 Amps.
jgialluca
