Forum >DIY Omni wheels robot
Recently I have designed this omni wheels robot, which can move on the ground agilely. This idea was inspired by a electronic trash can made one or two years ago by a Japanese guy, who in the video is throwing waste paper behind, knowing the controlled trash can will come up and catch the paper-ball. The algorism inside is that the trash can first identify the paper-ball, and then calculate the possible drop point, and fast move to that point in respond. The motion transmission mechanism is smartly designed too, using only two motors to achieve the whole motion, one enables the wheel move forward or backward, while the other controls the angle of turn.
In my design, I would like to improve the motion transmission mechanism. Instead of using ordinary wheels, I wanted to make a robot with omni wheels, driven by three 42 stepper motors. Robot Rovio was a good example for reference. I disassembled its movement mechanism and reverse engineered it. Then I started to think how to set up my own robot.
I decided to make an experiment version at the beginning, which was of low cost and easy to assemble. First, the frame should be assembled very low in space. Second, with enough strength, the wall of the frame should be as thin as possible. That’s how I made the first version with a simple round structure frame. The frame consisted of three triangle-shaped bases. Three omni wheels were equally spaced in the gap of bases, while each of them was driven by a 42mm stepper motor assembled on frame. In order to avoid barrier, a Robopeak laser radar was assembled on a round laser cut acrylic board at the top of the robot.
Once the mechanical parts were done, I started to build electrical parts. I made a temporary single sided PCB by heat transfer printing method (first transfer printing, then corroding, drilling, and at last welding). The electric schematic diagram was referred to DreamMaker 3D printer main board. The stepper drivers’ signal pins are defined as the three axis movement of the 3D printer. In addition, a relay (5V to drive) was designed on to the board.
with pcb&sch file download:
2015-01-08 06:14:31 Hey guys,
We should inspire his DIY spirit.
As I know, Swanglei is a mechanical engineer, and he is not good at coding and electron things.
HAHAHAHA
;D ;D ;D ;D ;D
Grey.CC
HAHAHAHA
;D ;D ;D ;D ;D
2015-01-07 17:02:27 Ive always wondered how hard it is to DIY, cos the tint film is readily available and they make it look so easy to put it on
KavomatovlKiz
2014-08-26 19:35:30 /*********************************************************************/
Code Author:DFRobot-Kelvin
Control Protocol?x100-y100-w100
X Direction:100mm/s
Y Direction:100mm/s
rotation to the left:100mm/s
#include <Metro.h>
double AcceleratedSpeed=400,whieelAcceleratedSpeed=500;//
double Step=0.03;//15*3.14/200/16
int xPul=25,
xDir=23,
xEnable=27,
yPul=31,
yDir=33,
yEnable=29,
zPul=37,
zDir=39,
zEnable=35,
km_1=8;
Metro _Serial_=Metro(20);
double xspeed,yspeed,zspeed;
static double xSpeed,ySpeed,wheel;
long x_t,y_t,z_t;
// put your setup code here, to run once:
Serial3.begin(115200);
pinMode(8,OUTPUT);
pinMode(xPul,OUTPUT);
pinMode(xDir,OUTPUT);
pinMode(yPul,OUTPUT);
pinMode(yDir,OUTPUT);
pinMode(zPul,OUTPUT);
pinMode(zDir,OUTPUT);
pinMode(xEnable,OUTPUT);
pinMode(yEnable,OUTPUT);
pinMode(zEnable,OUTPUT);
digitalWrite(xEnable,LOW);
digitalWrite(yEnable,LOW);
digitalWrite(zEnable,LOW);
digitalWrite(km_1,HIGH);
// put your main code here, to run repeatedly:
static long t;
if(_Serial_.check()==1)
serial();
Speed(xSpeed,ySpeed,AcceleratedSpeed);
// Wheel(wheel);
if(xspeed!=0)
x_t=int(Step/abs(xspeed)*1000000);
if(yspeed!=0)
y_t=int(Step/abs(yspeed)*1000000);
if(zspeed!=0)
z_t=int(Step/abs(zspeed)*1000000);
if(xspeed>0)
digitalWrite(xDir,HIGH);
else
digitalWrite(xDir,LOW);
if(yspeed>0)
digitalWrite(yDir,HIGH);
else
digitalWrite(yDir,LOW);
if(zspeed>0)
digitalWrite(zDir,LOW);
else
digitalWrite(zDir,HIGH);
xMove(xspeed);
yMove(yspeed);
zMove(zspeed);
void serial()
if(Serial3.available()==0) return;
char buf=Serial3.read();
switch(buf)
case 120://x
xSpeed=Serial3.parseInt();
break;
case 121://y
ySpeed=Serial3.parseInt();
break;
case 119://w
wheel=Serial3.parsedouble();
break;
void Speed(double XSpeed,double YSpeed,double a)
static double S_XSpeed=0,S_YSpeed=0;
if (XSpeed>S_XSpeed)
S_XSpeed=S_XSpeed+a*0.02;
if(S_XSpeed>XSpeed)
S_XSpeed=XSpeed;
else{
S_XSpeed=S_XSpeed-a*0.02;
if(S_XSpeed<XSpeed)
S_XSpeed=XSpeed;
if (YSpeed>S_YSpeed)
S_YSpeed=S_YSpeed+a*0.02;
if(S_YSpeed>YSpeed)
S_YSpeed=YSpeed;
else{
S_YSpeed=S_YSpeed-a*0.02;
if(S_YSpeed<YSpeed)
S_YSpeed=YSpeed;
xspeed=0.5*(S_XSpeed+1.732*S_YSpeed);
yspeed=0.5*(S_XSpeed-1.732*S_YSpeed);
zspeed=S_XSpeed;
void Wheel(double _wheel)
static double wheelspeed=0;
if(_wheel>wheelspeed)
wheelspeed=wheelspeed+whieelAcceleratedSpeed*0.02;
if(_wheel<wheelspeed)
wheelspeed=_wheel;
else
wheelspeed=wheelspeed-whieelAcceleratedSpeed*0.02;
wheelspeed=_wheel;
xspeed=xspeed+wheelspeed;
yspeed=yspeed+wheelspeed;
zspeed=zspeed-wheelspeed;
void xMove(double xs)
static long x_time=micros();
if(xs!=0)
if(micros()-x_time>=x_t)
digitalWrite(xPul,HIGH);
digitalWrite(xPul,LOW);
x_time=micros();
void yMove(double ys)
static long y_time=micros();
if(ys!=0)
if(micros()-y_time>=y_t)
digitalWrite(yPul,HIGH);
digitalWrite(yPul,LOW);
y_time=micros();
void zMove(double zs)
static long z_time=micros();
if(zs!=0)
if(micros()-z_time>=z_t)
digitalWrite(zPul,HIGH);
digitalWrite(zPul,LOW);
z_time=micros();
Swanglei
X Direction:100mm/s
Y Direction:100mm/s
#include <Metro.h>
int xPul=25,
xDir=23,
xEnable=27,
yPul=31,
yDir=33,
yEnable=29,
zPul=37,
zDir=39,
zEnable=35,
km_1=8;
long x_t,y_t,z_t;
pinMode(8,OUTPUT);
static long t;
serial();
// Wheel(wheel);
if(xspeed!=0)
if(yspeed!=0)
if(zspeed!=0)
if(xspeed>0)
else
if(yspeed>0)
else
if(zspeed>0)
else
xMove(xspeed);
yMove(yspeed);
zMove(zspeed);
void serial()
switch(buf)
case 120://x
break;
case 121://y
break;
case 119://w
break;
if(S_XSpeed>XSpeed)
S_XSpeed=XSpeed;
else{
if(S_XSpeed<XSpeed)
S_XSpeed=XSpeed;
if(S_YSpeed>YSpeed)
S_YSpeed=YSpeed;
else{
if(S_YSpeed<YSpeed)
S_YSpeed=YSpeed;
zspeed=S_XSpeed;
wheelspeed=_wheel;
else
wheelspeed=_wheel;
if(xs!=0)
x_time=micros();
if(ys!=0)
y_time=micros();
if(zs!=0)
z_time=micros();
2014-08-26 19:31:14 Awesome! Master Wang,
I will appreciate if you could display a short video about how to work? That will be interesting.
And could you make a popularization of sciences to tell us its working principle, mechanical design diagram or anything else?
Whether it will be KIT in the further?
Grey.CC
2014-08-26 19:05:02 And the PCB design
I used heat transfer machine to make the pcb and drill the holes(make me crazy)
Swanglei
