Forum >USB BLE Link upload sketch problem (TEL0087)
Bluno General Arduino
userHead Account cancelled 2017-08-11 23:40:09 2965 Views1 Replies
I have several new BLE Link devices and can't upload scetches to any of them.
I use win 10 and tried with both Arduino 1.0.7 and 1.8.3.
I have updated the firmware to "SBL_central_apdaterV1.98-30CM" and set the AT settings to default using serial monitor. I always find the COM port in Arduino IDE but can never upload any sketch to any device. Wiki suggests it could be a problem with the main chip bootloader, but is it likely as it happens to all devices?
There is a program running on the devices as I can connect over BLE with an Arduino 101. Both the LED on the Arduino and the dongle light up using this sketch on the 101:
#include "BLESerial.h"
pinMode(13, OUTPUT);
Serial.begin(115200); // initialize serial communication
BLESerial.setName("Bluno101");
BLESerial.begin();
//Serial.println("Bluetooth device active, waiting for connections...");
while(!BLESerial);
while (BLESerial.operator bool())
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
Would the program be running without MC bootloader?
Edit: The IDE error:
Arduino:1.8.3 (Windows 10), Kort:"Arduino/Genuino Uno"
Sketch uses 1460 bytes (4%) of program storage space. Maximum is 32256 bytes.
Global variables use 184 bytes (8%) of dynamic memory, leaving 1864 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xeb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xeb
Problem vid uppladdning till brädan. Se http://www.arduino.cc/en/Guide/Troubleshooting#upload för förslag.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
2017-08-25 19:02:40 Because BLE link only have an CC2540 in it, you can't upload code to it, it's just a Bluetooth module userHeadPic robert.chen
