Forum >Deep sleep power consumption firebeetle 32 v1.0
Easy IoT General
userHead andrew.rowbottom 2017-08-14 22:05:47 3097 Views1 Replies
I have a firebeetle32 v1.0 board.
When I put it into deep sleep (pcbreflux code, and similar arduino code) I'm measuring about 900ua with 3.2v (Lifepo4) connected to the gnd and 3.3v pins.
Yet https://www.dfrobot.com/blog-649.html is showing 1/10th that.
Is there something special I need to do? Am I connected to the wrong pins? Or are the later revisions better?
2017-08-25 22:14:11 Beginning to get somewhere with this finally! I've only managed a couple of tests, but the current draw in deep-sleep seems to depend the input voltage..
Using a 3.3v supply I get a deep sleep in the region of 35uA (both using vcc and 3v3 pins as power in)
But with an input voltage of 3.0v I get something in the region of 700+ uA
It seems strange to draw more with just a 10% drop in supply, but in a couple of tests its been repeatable.
I was originally testing with a moderately discharged LifePo4 battery, with a full charge battery the voltage is ~3.3v and the deep sleep current is low. I'll now have to use it a bit until it drops to its stable voltage which is closer to 3.2v and see what happens.
Will keep you posted
userHeadPic andrew.rowbottom
