Make a small Measuring Wheel with Arduino UNO
Open Google map, input starting point and destination then the distance will display in your screen. Compared to traditional maps, the current electronic maps are of vast information and better distance calculation. However, how could it counts the distance? Is it uses satellite, tape or other tools? Satellite can explore topography and land resource but lack of precision; tape is inflexible and distance limited. Except these tools, is there anything else? Couple of days before, I was suddenly to find a man who holds a wheel rolling along the road. I was incontinent of curiosity, I came to talk with the man and knew he is a map worker and used the wheel to measure distance then draw routes. The distance measure wheel is convenient to take, flexible and precise. How could I resist its temptation to make a measuring wheel? Relative to old tape, the wheel can slip freely and detect positive and negative (slip to left is positive, slip to right is negative). Let us see the working process.
Hardware Diagram Main Hardware In this project, I would love to chooseDFRduino UNO R3 that fully compatible withArduino UNO R3 as a main board. It adopts ENIG (emersion gold) technique, cost effective and more delicate. Moreover, we need another powerful component which is an encoder to count distance. Incremental Photoelectric Rotary Encoder - 400P/R is compatible with controllers such as Arduino, PLC etc. It generates AB two-phase orthogonal pulse signals though the rotation of the grating disk and opt coupler. The output type is NPN open collector output, which could work with Microcontroller with internal pull-up resistors directly and realize speed, angle, angular velocity and other data measurement.
*Caution: NPN open collector output needs pull-up resistors for the oscilloscope display.
Main Components
Gravity: I2C 16x2 Arduino LCD with RGB Backlight Display
Cable Adapter Module 4
Gravity: IO Expansion Shield for Arduino V7.1
Digital Push Button (.NET Gadgeteer Compatible)
7.4V Lipo 2500mAh Battery (Arduino Power Jack)
D80mm Silicone Wheel For TT Motor
Circuit Diagram Real Connected Picture Rendering
Reset: you could clear up data and make a restart measurement more convenient in this mode. Detection: You can measure distance freely, up to down, right to left in this mode. Slipping to left, the value is positive; slipping to right, the result is negative (when the value is a positive one, rolling right and the result is decreasing). Lock: when the measurement finished, you need to keep data. In this mode, all data is locked and would not change that helps you record results. It works with simply three presses.
I have print a crust by 3D printer to make it convenient to take and more beautiful. Is it looks a little unnatural? The crust is too square. I am sorry but I have tried my best. I believe your ideas must better than mine. The 3D printing file is in the end page.
*Caution: I have make a 80mm hub with 3D printer to suit the wheel.Tires of quality enviromentally friendly D80mm Silicone Wheel For TT Motor is still in use. Program:
Main Components
#include <Wire.h>
#include "DFRobot_RGBLCD.h"
DFRobot_RGBLCD lcd(0x7c >> 1, 0xc0 >> 1, 16, 2);
//rgb_lcd lcd;
#define A 3
#define B 4
#define Key 12//key
#define D 79 //Diameter 79mm
float C = 0; //perimeter
unsigned int Distance;
int VA = 0;
int VB = 0;
unsigned long Count = 0;//count
unsigned int Count_1 = 0; //Negative count
unsigned char flag = 1, Mark = 0;
unsigned long lasttime = 0, Modetime = 0;
//Length measurement range is ± 6 M
Serial.begin(9600);
lcd.init();
lcd.setRGB(255, 255,0);
lcd.setCursor(2, 0 );
lcd.print("M:");
lcd.setCursor(2, 1 );
lcd.print("D:");
lcd.setCursor(12, 1 );
lcd.print("cm");
pinMode(A, INPUT_PULLUP); //Pull-up input
pinMode(B, INPUT_PULLUP);
pinMode(Key, INPUT);
attachInterrupt(1, interrupt, RISING);
C = D * PI;
if (millis() - 150 > lasttime)//Detect keys once every 150ms
if (digitalRead(Key) == HIGH)
Mark += 1;
if (Mark > 2)
Mark = 0;
while (digitalRead(Key) == HIGH);
lasttime = millis();
if (millis() - 100 > Modetime)//Refresh the data every 100ms
if (Mark == 0) //Cleared
lcd.setCursor(6, 0 );
lcd.print("Reset ");
Distance = C * Count / 40;
flag = 3;
lcd.setCursor(11, 0 );
lcd.print(" ");
if (Mark == 1) //Calculate the measured value
lcd.print("Detection");//
lcd.setCursor(4, 1 );
if (Count > 0 && Count < 0xffff)//Determine whether the length is positive
lcd.print('-');//The length is negative
else if (Count == 0 && Count_1 == 0 )//Determine whether the length is zero
lcd.print(' ');
else//Length is positive
lcd.print('+');
Distance = Count_1 * C / 40;
else if (Mark == 2) //lock
lcd.print("Lock ");
Count = 0;
Count_1 = 0;
Modetime = millis();
lcd.setCursor(5, 1 );//Displays the value of Distance
lcd.print(Distance / 10000);
lcd.print((Distance / 1000) % 10);
lcd.print((Distance / 100) % 10);
lcd.print('.');
lcd.print((Distance / 10) % 10);
lcd.print(Distance % 10);
void interrupt()//Interrupt handler
VB = digitalRead(B);
if (Mark == 1)//Detects whether the current mode is a measurement
if (VB == 1)//To determine whether the positive measurement
flag = 1;
if (Count > 0xffff)
Count_1 -= 1;
Count += 1;
else//Reverse measurement
flag = 0;
Count -= 1;
if (Count > 0xFFFF)
Count_1 += 1;
//Count is cleared over the range
if (Count < 0xFFFF && Count > 0x294A)
Count = 0;
else if (Count < 0xFFFFD6B5 && Count > 0xFFFF)
Count = 0;
1.jpg Download(0)
2.jpg Download(0)
3.jpg Download(0)
521_P_1415674112537.jpg Download(0)
1407_P_1498208751308.jpg Download(0)
3D Printing Files.rar Download(0)
4.png Download(0)
配件图.jpg Download(0)
图2.jpg Download(0)
图3.jpg Download(0)
DSC_4781.jpg Download(0)
1.jpg Download(0)
2.jpg Download(0)
2019-04-02 04:59:01 Hi,
Rebuilding the project results is al screen with one line black and no other action?
What can be wrong? markhermens
2018-08-14 12:12:52
Gravity IO expansion board cossojohnalexyichengwang wrote: ↑Fri Jul 20, 2018 4:19 pmHi there,
I am wondering what is the board that's used to connect the rotary encoder with the controller board?
Thank you,
Alex Wang
2018-08-14 12:12:52
Thank you,
Alex Wang
2018-08-14 12:12:00 I am having issue with remaking this same project. I do not have the Push Button because DFRobot did not send it with my order. How can I by pass that I have the correct libraries and code but my LCD is not even lighting up with the "M:" and "D:". I did check to see if it works an it does as well as the rotary encoder. cossojohn
2018-07-21 08:19:46 Hi there,
Thank you,
Alex Wang alexyichengwang
Thank you,
Thank you,
Thank you,
2018-04-23 18:23:24 I want the measurement results in Gravity LCD 1602 RGB can also be read and displayed in VB6 application then the data I will process on my VB6 application.
While VB6 only recognize RS232 port, do not know USB port, do I need to add part RS232 TTL Coverter?
How to schema with RS323 TTL converter and how to coding in VB6? anonymous
2018-02-27 01:22:17
Why do you want to use VB6? Are you using arduino as the main controller? robert.chenplinteng.semar wrote: ↑Sun Feb 25, 2018 4:24 pmCan the measurement result be read with VB6?
Please share the program/coding
Thank you.
2018-02-27 01:22:17
Thank you.
2018-02-26 08:24:33 Can the measurement result be read with VB6?
Thank you. anonymous
2017-09-26 17:23:01
With fixed library files 1078883988tridithings wrote: ↑Tue Sep 12, 2017 8:17 amdear admin,
at program was stated "#include <Wire.h>
#include "DFRobot_RGBLCD.h", but where are they?
2017-09-26 17:23:01
2017-09-13 00:17:39 dear admin,
#include "DFRobot_RGBLCD.h", but where are they? tridithings
2017-08-14 22:30:14 Make a small Measuring Wheel with Arduino UNO
Main Components
Main Components
1078883988 #include <Wire.h>
//rgb_lcd lcd;
#define A 3
#define B 4
#define Key 12//key
int VA = 0;
int VB = 0;
Serial.begin(9600);
lcd.init();
lcd.print("M:");
lcd.print("D:");
lcd.print("cm");
C = D * PI;
Mark += 1;
if (Mark > 2)
Mark = 0;
flag = 3;
lcd.print(" ");
lcd.print(' ');
lcd.print('+');
lcd.print("Lock ");
Count = 0;
Count_1 = 0;
lcd.print('.');
flag = 1;
if (Count > 0xffff)
Count_1 -= 1;
Count += 1;
flag = 0;
Count -= 1;
if (Count > 0xFFFF)
Count_1 += 1;
Count = 0;
Count = 0;
