Forum >Motor driver/controller
RoboticsGeneral
userHead Account cancelled 2017-08-16 00:49:32 1897 Views1 Replies
Is there available a motor driver/controller that could be used to drive the motor at the link below at 75rpm while exerting a torque of 38Kg.cm?
The motor that I am hoping to use is at https://www.dfrobot.com/product-1210.html
Best regards
2017-08-25 23:10:02 38Kg.cm is the stall torque of this motor which means the speed would be zero in that case userHeadPic robert.chen
